Backtest report with MT4
Nico2019
Post by Nico2019 »
Good morning! I have a problem with the MT4 Backtest report.
At the beginning when I read the report I got the quality of the model in Light Green with 99.9% written, now after I downloaded a new database that arrives until mid-March, I don't get 99,9%anymore, now go out n/a but the bar is always light green, as if the model were 99.9% reliable.
What should I do Can I trust the results or should I do something?
In short, what does it mean when the number 99.9% does not come out as model quality, but the word "N / A" comes out with the light green model bar?
Re: Backtest report with MT4
Good morning Nico,
If you're getting N/A modelling quality, it's most likely that you haven't pressed the 'Launch' button in Tickstory to launch MT4. Please do this and see if this resolves the issue (the Launch button needs to be pressed once to start up MT4).
You can see a list of causes of 'N/A' modelling quality and how to resolve them here:
https://tickstory.com/help/tickstorylit ... ng_quality
