Excel issue with tick export time stamp
TradeBuilder
Post by TradeBuilder »
I exported AUDCAD ticks for two days to see the format TickStory produces. I used date, time, ask and bid price. The confusing field is time. It starts at 00:00.1 — which seems fine until I see 59:59:0 at the end of the day.
What am I looking at for time and why not a 24 hour per day time?
Re: Please explain tick export time stamp
Hi TraderBuilder,
That doesn't sound right. Are you sure you are not inadvertently using the "mm" specifier for the hour instead of 24-hour "HH"?
If you send us a screenshot of the format you are using we can assist further.
TradeBuilder
This is the setup and the result in An Excel spreadsheet:
ZIP file with export attached
Thanks for having a look.
Hi TradeBuilder,
Looking at the raw file you provided in a text editor, here are the actual last entries for the 29/6/20:
20200629 23:59:44,23:59:44.010,1.1238,1.12377
20200629 23:59:44,23:59:44.782,1.12381,1.12377
20200629 23:59:46,23:59:46.814,1.1238,1.12377
20200629 23:59:48,23:59:48.635,1.12381,1.12377
20200630 00:00:04,00:00:04.615,1.12381,1.12379
20200630 00:00:04,00:00:04.716,1.12382,1.1238
From this, it appears that there is some formatting issue in your Excel spreadsheet that you will need to fix.
TradeBuilder
OMG! Thank you. My earlier file was too big to see in a text editor so I loaded it into Excel. Thank you.
You're welcome! ;)
