How to configure Tickstory
TraderConfirm
Post by TraderConfirm »
i saw HST directory and FXT directory
For XM how to choose folder ??
TraderConfirm
Re: how to set up
and can not dowload
Re: how to set up
Hi TraderConfirm,
In Tickstory's File->Settings->MT4 Settings, select the "Installation Folder" which is the folder where you installed MT4. The Installation Folder is where the application (terminal.exe) is located and looks it is "C:\Program Files\XM Global" in your case.
The other settings will be automatically detected based on this.
You can find more information on how to set up Tickstory in our manual here: https://tickstory.com/help/tickstorylit ... _tickstory
