Cannot open mt4 for backtesting
delvinongyj
Post by delvinongyj »
Hello
I am facing issue clicking on the "open MT4 for backtesting" button from tickstory.
After clicking in, it says "A suitable launcher could not be found”
I am using ICMarkets
Version for tickstory is 1.9.6.1
Version of MT4 is 4.00 build 1320 11 Dec 2020
Please advise.
Current testing from MT4 strategy tester directly does not yield 99.90% only 30-40%.
Re: Cannot open mt4 for backtesting
Hi Delvinongyj,
Sometimes the launcher may raise this message if MT4 takes too long to start. If you click on the launch button after MT4 has started, this may resolve the issue. Other things to check are mentioned in our FAQ here.
For the modelling quality, please check out our FAQ here and some of these previous threads which should assist you:
viewtopic.php?f=2&t=2571
viewtopic.php?f=2&t=2184&p=9505
If you have further questions, please send some screenshots of the issue.
