I get this error immediately after launching the program for the first time:
Product name: AdvancedTester
Product version: 0.0.3.1
Details:
Value of '1/7/2021 12:00:00 AM' is not valid for 'Value'. 'Value' should be between 'MinDate' and 'MaxDate'.
Parameter name: Value
at System.Windows.Forms.DateTimePicker.set_Value(DateTime value)
at . ()
at . ()
at . (Object , EventArgs )
at System.Windows.Forms.Form.OnShown(EventArgs e)
at System.Windows.Forms.Form.CallShownEvent()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
Error at opening of ATM
Re: Error at opening of ATM
Thanks for your issue report, Gin. Could you please tell us what regional settings you have? It looks like it might have something to do with date formatting.
Probably yes:
I am currently situated in Germany while I am using a English/USA regional format in windows10.
Hi Gin,
Thanks for the information. We unfortunately couldn't reproduce the issue but we've identified what could be the problem.
Could you please use your beta download link to get the latest v0.0.3.3 and see if this fixes the issue for you?
Great news! Thanks for letting us know. We've sent you something in a private message as a thanks for helping us find an issue
