When I download the data and include BidPrice and Ask Price, both of these variables stay fix across time.
Do you have a solution?
Best regards,
Nicolas
AskPrice and BidPrice doesn't change
Re: AskPrice and BidPrice doesn't change
Hi Nicolas,
If you are using Tick-based output tokens (eg. {BidPrice}), please make sure you have selected the "Tick" time-frame, otherwise you will not get the correct values since they are not applicable to any "bar" time-frames.
You can read more about this in our manual here:
https://tickstory.com/help/tickstorylit ... ile_export
