Advanced Tester - Error Loading Predef.set file
danielfcastro
Post by danielfcastro »
How to reproduce
1 - I add my MT4 installation (MT4 installation Screenshot)
2 - Perform a test setup (TestSetup Screenshot)
3 - Confirm that the preset is where it is supposed to be (preseetfile screenshot)
4 - Click on Start or BEgin (mine is in portuguese and shows as Começar) (Screenshot Start)
5 - The error happens
Re: Advanced Tester - Error Loading Predef.set file
Hi Daniel,
Did you intend to include some screenshots? If so, that would definitely help understand the error you are getting.
Also, please make sure that the .set file is in the <mt4 data folder>/tester folder for it to be found.
