Server settings in ATM
jhenares
Post by jhenares »
In MT4 my only terminat in ATM, it is showed Ava-Demo as server. I change it to Ava-Real 1. Update and save. Buy Ava-Demo comes up again. There is no woay to change ir.
Helpo appreciated
Re: Server settings in ATM
Hi Jhenares,
Thanks for raising this. We can confirm there is an issue and we will have a fix out shortly.
In the mean-time, it appears that this is only a visual issue - that is, if you press "OK" on your desired settings, they are in-fact saved and you should be able to continue as normal.
Hi Jhenares,
Just to let you know that this has now been addressed in the latest v0.0.3.9b.
