Swaps & 3-day swap roll-over
elliot_123
Post by elliot_123 »
hi during testing what do I put in the 3 days rollover for swap. i selected swap checkbox points and mt4 crashed. and if i select 3 day rollover checkbox it crashes too. it only works when i have the long and short swap selected for testing
Re: Swaps & 3-day swap roll-over
Hi Elliot,
The 'swap' fields denote the amount payable if you hold your position overnight. For example, if you set the 'Swap type' to 'Interest' and 'Swap long/short' to 0.11, then you will pay 0.11% interest on overnight positions. The 'Roll-over 3 days' is the day of the week (0=Sunday, 1=Monday, etc) that you will be charged additionally for holding a position over the 3-day weekend.
Generally speaking you should just leave these values at your broker-set values unless you have something specific you wish to test. You should not set them to empty values as you are likely to end up with a problem. Any field highlighted in red will cause a problem, so please ensure you correct it before attempting to back-test.
