Unable to Launch MT4 Via Tickstory (Terminal.exe not found)
jmawirat
Post by jmawirat »
I am unable to launch MT4 via Tickstory. Please note that the meta trader installation directory and data folder are already placed correctly.
Error Message:
Terminal.exe Not Found.
Screen Shot 2021-12-11 at 10.03.29 PM.png (11 KiB) Viewed 4979 times
Re: Unable to Launch MT4 Via Tickstory (Terminal.exe not found)
Hi Jmawirat,
Thanks for the screenshots. You have not selected the correct "MT4 Installation folder". Please select the correct program files folder. It should be the same one you installed MT4 into and should contain a program called "terminal.exe" which is the Metatrader application.
By default MT4 installs in the C:\Program Files (x86) folder, so please search for it there. If you still don't know where you installed it, then check your Windows Start Menu -> Metatrader and then right-click the icon and check the Properties to see the location.
Once you select the correct MT4 Installation folder, other settings such as the MT4 Data folder will automatically be detected.
