MT4 Location Change Bug
Beepsi
Post by Beepsi »
when you change the location of MT4 you have to restart TickStory first as otherwise it wont load MT4 from the new location.
Bad for lazy ppl :)
I change MT4 locations as I run multiple versions of MT4 in parallel for backtesting with different values and to use my CPU at 100% for that.
Would be supercool if we could get an option to start different MT4 installations and choose how many and which one :mrgreen:
Beepsi
Re: MT4 Location Change Bug
Hi Beepsi,
Thanks for the feedback. Yes, the settings for the launcher are set once at start up. We are working on addressing the ability on supporting multiple Metatrader 4 installations which should be available on the next major upgrade of the software.
