(Use Tickstory) Button missing
jou
Post by jou »
I used TickStory a few months ago and bought a new license today.
As far as I remember, there should be a box right there saying (Use Tickstory), and a window would pop-up where I can select the pair, slippage spread, etc.
What am I missing?
Re: (Use Tickstory) Button missing
Hi Jou,
Our software does not embed in MT4 in this way. What we have is a product called the Advanced Tester which allows you to manage all your MT4 test configuration (slippage, spread, etc) for each running terminal. The Advanced Tester also allows you to perform Walk-Forward analysis on selected terminals. You can download our Advanced Tester from our beta page (FYI, the software is in final beta - there are no known issues with the tester at this stage, however we will make an official release with our next generation of Tickstory v2 in the coming months).
