MT4 operating version (MT4 Build 1369)
alextc
Post by alextc »
Hello!! Where can I find a version of MT4 that is supported by Tickstory? I currently have version 1367 and with it the results are n/a.
THX!!
Re: MT4 operating version (MT4 Build 1369)
Hi Alextc,
Tickstory v1.9.7.4 supports MT4 Build 1367. If you haven't already got this version (check Help->About), then please download and install it using your original download link. Then, as usual, make sure you press the 'Launch' button in Tickstory to start MT4 and you should get 99.9% modelling quality (please run though our trouble-shooting FAQ if you still have problems as this should resolve it).
alextc
Post by alextc »
Thanks for the reply. I have uninstalled everything and reinstalled it, and nothing, it still gives n/a.
Ticksotry launches the MT4 but at the same time I get an error message saying the versions it supports (among which mine is not)
What could be the problem?
Hi Alextc,
If you are using Tickstory v1.9.7.4 and there is a launcher error, it should mention that it tried the launcher for MT Build 1367 in the error message.
Could you please confirm you are using Tickstory v1.9.7.4? And if you are still having issues, could you please give us a screenshot of the error you are seeing?
alextc
Post by alextc »
Yes, I confirm that the version I use is 1.9.7.4
I attach a screenshot with the error.
Thanks, Alextc. The error message does mention Build 1367 which also confirms you are using the latest Tickstory version. Could you please manually start your MT4 and then press the 'Launch' button to see if that helps? Also, please confirm your MT4 Build number in Help->About and also that you are not running any other software that augments/uses MT4?
alextc
Post by alextc »
The version of MT4 that I have installed is 1369, sorry.
Where do I find the 1367? It's from Tickmill
And no, it doesn't work doing what you told me
Hi Alextc,
Thanks for the further information. It all makes sense now - you have a new version of MT4 ;) We've sent you a private message with a link to an update that should resolve the launch issue for Build 1369. Could you please let us know how you go. We will make an official release of it shortly.
alextc
Post by alextc »
OKAY!! Yes now!!! perfect. 99.9% quality.
Thanks a lot!!!
Excellent - thanks for letting us know, Alextc. THe same version 1.9.7.5 is now officially available via your download link.
