Bypass MT4 limitation of input variables / max genetic opti
geektrader
Post by geektrader »
Since you seem to be very capable guys, I was wondering if you can do something so that MT4 will allow an unlimited amount of input combinations for the optimization (currently, if trying to optimize to many parameters at once it won´t let you do so, telling you to lower the amount of input parameters to be optimized). Also, the genetic optimization always only runs a max of 10496 combinations. It would be great if that could be "unlimited" too, so that it continues the optimization forever until I press STOP.
Many other programs like Multicharts can do this with ease, just MT4 limits you in these days of super fast CPU´s to stick to limitations that are not really needed.
Can you do something about that to "patch it" somehow via the launcher?
Re: Bypass MT4 limitation of input variables / max genetic o
Hi Geektrader,
Thanks for your feedback. Our main focus is developing the database capabilities of Tickstory, so it deviates a bit to be looking into how to improve MT4. Perhaps if you ask this question on an MT4 forum someone may be able to assist? It could also be an enhancement that Birt would consider with his Tick Data Suite: http://eareview.net/tick-data-suite?hop=referrer9
