cannot download AUDNZD
braunkf
Post by braunkf »
I cannot download AUDNZD data. Tickstory says it has problems connecting to the remote server. On the other hand it works with EURUSD. I am running windows xp and the latest version of tickstory. I have tried different download directories. What can I do ?
Regards,
KFB
Re: cannot download AUDNZD
Hi Braunkf,
Could you please give the exact error message you are getting and preferably a screenshot?
braunkf
Post by braunkf »
Translated into english: Error during download: Cannot establish connection to remote server. (URL: http://www.dukascopy.com/datafeed/AUDNZ ... _ticks.bi5)
Hi Braunkf,
The problem is more than likely due to some network issue on your side such as not being connected to the internet. To check your connection:
- Go to File->Settings->Dukascopy Datasource and press the 'Test' button.
If you get an error, you need to resolve the issue with your network first.
braunkf
Post by braunkf »
If I press the Test button it says: Cannot establish connection to the remote server.
My internet connection works fine.
I am able to download data which had been downloaded before already. If i am creating a similar filestructure for AUDNZD as well, then I there is no error message upon downloading anymore. So it seems to be related to access rights.
braunkf
Post by braunkf »
I solved the problem. I am using norton internet security which uses its own firewall. So windows firewall is switched off while Norton is on. Some settings must have changed because if i switch norton off as well then everything works fine.
Great to hear - thanks for letting us know how you solved it!
