MT5 Export; both ticks and M1
ausimike
Post by ausimike »
Sorry if this is already asked. I searched the site and I was certain that it would have already been discussed, however, there was no clear answer in past posts.
I am testing my eas and indicators in MT5. I know how to export data from Tickstory, however, when I save custom files, it only saves them as csv. while I require Json for mt5. I found a post that described how to create a custom file, that included both ticks and m1, howaever the file was saved as the wrong type. It can not be used with MT5.
I also require both tick and M1 data for using with MT5, however, the newer versions of Tickstory only have options to do 1 or the other. How do I save or export both Ticks and M1 data from Tickstory To MT5 strategy tester folders?
Re: MT5 Export; both ticks and M1
Hi Ausimike,
Please check out our guide to Importing Bar and Tick data to MT5 from Tickstory.
