Multicharts Compatibility
Antonio
Post by Antonio »
I'm new to Tickstory and would like to know if the data is readily compatible with Multicharts? (or, alternatively, how difficult it is to make it comptabile?). I do not plan on using MT4 or MT5.
Thank you.
Re: Multicharts Compatibility
Hi Antonio,
TIckstory is compatible with most charting packages that permit import of delimited data (eg. CSV, tab). If you have the specific format that Multicharts requires to import bar and tick data we can advise on the custom format you need to specify in Tickstory to produce the required data.
Antonio
Post by Antonio »
Sounds good. Thank you for the reply!
