Tickstory Lite issue on startup
admissqddw
Post by admissqddw »
When I open Tickstory
Software prompts
Like Tickstory?
It's time to go
Get our offer
Buy with cryptocurrency
I can't close this interface, it doesn't respond, I can only force close it in the Windows 10 operating system process options
Re: Tickstory Lite issue on startup
Hi Admissqddw,
Could you please try to run the Microsoft .NET v4.6.2 installation just in case something is corrupt with your installation? The screen should have a "Close" button at the bottom. You might be able to temporarily work around the issue by pressing "tab" to highlight the close button (even though it isn't visible) and pressing the space bar.
Please let us know if the .NET re-instalation helps.
