Allow folder selection for file export
gooly
Post by gooly »
Would you please add as well the path to be entered, where the csv-file will be created. The actual Tickstory-folder is not the one to have further fun with pair.csv :)
Thanks in advance,
gooly
Re: Wrong pre-defined format "CSV2FXT" when exporting to fil
Hi Gooly - not sure what you mean. The folder location of where the file will be written is already displayed.
gooly
Post by gooly »
Well I
- start Tickstory and
- click right mouse button over a pair
- select export in file (German: Datei)
I get a window to enter from..to, TimeFrame, .. file name (pre-defined {Symbol}.csv (here I can choose some other options)
but I don't have a button to select the folder where it'll be created.
I didn't try to enter a 'hard-coded' path "c:\\..."
So I searched a while until I found it in the Tickstory folder.
Hi Gooly,
You can specify the path manually - there is not folder selection button at the moment but we can note this. FYI we will move this part of the thread to the 'suggestions' section.
