Mi nombre es Anthony Oliveras , compre el sistema y estoy pagando la mensualidad,al bajar la version :1.9.7.16, el sistema me indica este error:
Code: Select all
Product name: Tickstory Lite
Product version: 1.9.7.16
Details:
Not found
at System.Management.ThreadDispatch.Start()
at System.Management.ManagementScope.Initialize()
at System.Management.ManagementObject.Initialize(Boolean getObject)
at System.Management.ManagementClass.GetInstances(EnumerationOptions options)
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=zy3k8Z2USoyqVlUDgrV4PuhGQrnJJh3vXqvwo5ko=(Exception #=zPjqh6yg=)
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=zF_mSs4MVZr80k$iz8uokHNSQ5NY1(Object #=zPjqh6yg=)
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=ztAmBOgVxOJJwzEEIrZX6tA4=(MethodBase #=zPjqh6yg=, Boolean #=z9bnAGJc=)
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=z1y0oFxdqRdAbAwcixGWomjr8rybQ(#=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o= #=zPjqh6yg=, #=q8403luDZkFwfaK4gpgHiOcgaDVAvx3c5TYdQqzavkzk= #=z9bnAGJc=)
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=zF1eOsDmOj5huF7rNNGt1SdUSY4c8()
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=zIIKjuefP1pGHv7pW0_vb5b7R2P$G(Boolean #=zPjqh6yg=)
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=zZPtIBtg44IVhbcW8FCvsqOO4fNtC()
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=zv6sonOFcKWOsqT9Tme563yWTrX5WNqMsE4tC8Mg=(Object #=zPjqh6yg=, UInt32 #=z9bnAGJc=)
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=z0mDtJjdJGRUC$Vvv_4f8loB6KaMMaBWFk_3uzkLBwcmg()
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=zsmYiYx1rKfRhFXTZKg3W9UFKlj_Fq6pjoBQV3TlAoD4i(Object[] #=zPjqh6yg=, Type[] #=z9bnAGJc=, Type[] #=zw9mCZJc=, Object[] #=zXGCLxLU=)
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=zP52MzY6Q$7nHGDZo3m95JSOSD$vo38TFQqKCvk_JZZJz(Stream #=zPjqh6yg=, Int32 #=z9bnAGJc=, Object[] #=zw9mCZJc=, Type[] #=zXGCLxLU=, Type[] #=z3hoJfqo=, Object[] #=zyxpmnlU=)
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=z_ywNXKoF0L31JosNTwcG2FaaUJkO(Int32 #=zPjqh6yg=, Type[] #=z9bnAGJc=, Type[] #=zw9mCZJc=, Boolean #=zXGCLxLU=)
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=zsaqxoiY7Pfd4tOHULg==(#=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o= #=zPjqh6yg=, #=q8403luDZkFwfaK4gpgHiOcgaDVAvx3c5TYdQqzavkzk= #=z9bnAGJc=)
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=zGd0l7oJEzynQIRIsukBTCl6VMHDwDqkK5tt3SHE=(Stream #=zPjqh6yg=, String #=z9bnAGJc=, Object[] #=zw9mCZJc=, Type[] #=zXGCLxLU=, Type[] #=z3hoJfqo=, Object[] #=zyxpmnlU=)
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=zcxnIePIUU_ooWd366Pw1MA4=(Stream #=zPjqh6yg=, String #=z9bnAGJc=, Object[] #=zw9mCZJc=)
at #=qYmzMDv5xVNbcBApLYfC2QVrJMxfJnKLuGh6CjepEH_o=.#=zxK8kNVVt90SG4BeTQ$qXnZGNIsMa(Stream #=zPjqh6yg=, String #=z9bnAGJc=, Object[] #=zw9mCZJc=)
at #=zfoLyFjqDkS1cwj61d3rB_Fo=.#=zdORYjVa3Fdqj(Object #=zRLxt_6I=, EventArgs #=zz_AM8dk=)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at #=zfoLyFjqDkS1cwj61d3rB_Fo=.WndProc(Message& #=zV_sfYgU=)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
