Broker Config file
CRegis
Broker Config file
Post by CRegis »
Hi please how to do this ?
You can force a valid filename by going to the EA's '*ConfigFileName*' parameter to “Broker.mt4config”.
Re: Broker Config file
Hi CRegis,
You can set the broker config file name in the "Expert Properties" of TickstoryInfoExpert as shown in the screenshot below.
TickstoryInfoExpert settings
Please note that use of these config files have been largely obsolesced by simply selecting your broker symbol in the MT4 Settings->Map To screen as shown in the attached screenshot. As soon as you select your symbol in the "Map to" box, your broker's symbol's properties are automatically set. Please refer to our manual for more.
Map to selection
Map to selection
