Cannot import Data as .CSV
rogerchee
Post by rogerchee »
Greetings,
ive face issue regarding importing of data downloaded as .CSV
According to my ICMarket MT5 platform, after selecting, Symbol, Create symbol, Import, ( My specific locaion ). It only allows upload of .JSON instead of " All Files "
Theres no other selection. If any kind soul give me advise on this. would be much appreciate.
Re: Cannot import Data as .CSV
Hi Rogerchee,
You are selecting 'Symbol import' instead of 'Bar/tick data import'. Please follow this guide carefully and it should resolve your query.
rogerchee
Post by rogerchee »
appreciate your reply. Thanks! will try
