Was a Lite User and Just bought Standard.
skarragallagher
Post by skarragallagher »
Finally got the full version only to be prompted with this nonsense
I purchased the software, then downloaded and installed the standard version, Only to be prompted with an Application Error.
I tried uninstalling and reinstalling completely however no joy, i can bypass this but i can't download anything or input my license key
Should have just stuck with the lite version :(
Code: Select all
Product name: Tickstory Lite
Product version: 1.9.8.3
Details:
Not found
   at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
   at System.Management.ManagementObject.Initialize(Boolean getObject)
   at System.Management.ManagementBaseObject.get_ClassName()
   at System.Management.ManagementClass.GetInstances(EnumerationOptions options)
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=z09FAGyy974jf9mws8vszU41tv7RuBPCc5PACF$k=(Exception #=z6tqpiY0=)
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=zQWU8uHojM3gMJqXfUvmLqzj_WbCF(Object #=z6tqpiY0=)
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=zxw5o_8MS0N2zmrtHp4NR_Ic=(MethodBase #=z6tqpiY0=, Boolean #=zdPSCTwQ=)
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=z$IjWHO1g3JBoHYyKAsnvDQWphrQv(#=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0= #=z6tqpiY0=, #=qy3yXU0lyi8PgT4_cTa6NZ2W3wvScfsK3Fin2F4By1fE= #=zdPSCTwQ=)
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=zl9p8xnF0gU7Ug8DXaKkVLnWa9b_9()
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=zvmUUSTzq5hP0HOBQHmy9864$aRgJ(Boolean #=z6tqpiY0=)
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=zo9Is8JleVLD5NP0kEMuXGetPAyIi()
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=zfG1bxdtW4xplt4X0d1UmZeR4TdjI7TdO2COT4fM=(Object #=z6tqpiY0=, UInt32 #=zdPSCTwQ=)
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=zgWjelSMdB4_030eEWJBrMvbQiq_OkqoyZuFr$0OwZFsw()
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=zSdY0ESoNooiibpEg8vwpzc2DCb1MZfEdZU2qe$ULze55(Object[] #=z6tqpiY0=, Type[] #=zdPSCTwQ=, Type[] #=zG0XOzTk=, Object[] #=zfqkQ$l0=)
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=zHUOIJ8LckLjA9d2y1rZO6YVcH8My_j5NYTk41u2CLOcf(Stream #=z6tqpiY0=, Int32 #=zdPSCTwQ=, Object[] #=zG0XOzTk=, Type[] #=zfqkQ$l0=, Type[] #=zkD$0V5Q=, Object[] #=zsHSrfjw=)
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=zSpSbU2bBQKozWhwBrw79JTC03eU8(Int32 #=z6tqpiY0=, Type[] #=zdPSCTwQ=, Type[] #=zG0XOzTk=, Boolean #=zfqkQ$l0=)
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=z$YDAViguB8ETkGyemA==(#=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0= #=z6tqpiY0=, #=qy3yXU0lyi8PgT4_cTa6NZ2W3wvScfsK3Fin2F4By1fE= #=zdPSCTwQ=)
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=zi69N3978aqGHvc6pGerMMXDRK7gbBCpcF8jYI1o=(Stream #=z6tqpiY0=, String #=zdPSCTwQ=, Object[] #=zG0XOzTk=, Type[] #=zfqkQ$l0=, Type[] #=zkD$0V5Q=, Object[] #=zsHSrfjw=)
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=zS89Zi_8DPI2XqHLKlRozi88=(Stream #=z6tqpiY0=, String #=zdPSCTwQ=, Object[] #=zG0XOzTk=)
   at #=q9s2$Bw7$bEIIjilf$lcQ4GVwUWc1DsHOr2WV2DOpie0=.#=zPGodHQ4v1xQqk6$rAWP3IhLDNWWH(Stream #=z6tqpiY0=, String #=zdPSCTwQ=, Object[] #=zG0XOzTk=)
   at #=zdImVYKXKquHUeOvMcwELZ$w=.#=zC4SteMfFHJIU(Object #=zoVtBlPs=, EventArgs #=z4YQtm2s=)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at #=zdImVYKXKquHUeOvMcwELZ$w=.WndProc(Message& #=zCKvV9RA=)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Re: Was a Lite User and Just bought Standard.
Hi skarragallagher,
Thanks for your recent purchase. The error you are getting is due to a missing/corrupted Windows component that Tickstory requires to function (the licensed version has additional functionality and hence additional Windows components are required).
Could you please check out these posts to resolve it:
https://tickstory.com/forum/viewtopic.p ... 856#p12856
https://tickstory.com/forum/viewtopic.p ... 203#p10203
skarragallagher
Thank you for the reply. That solved my issues, i had rebuild the WMI stuff
Awesome! That's for letting us know you solved it.
