Can I move where I want to test my data (to a VPS)
Graham Stewart
Post by Graham Stewart »
Hi, I bought the data package and was testing on my computer and the back tests were just too hard on my computer so I decided to get a VPS to test on there. I have no problem stopping testing on my computer and just on my VPS, I would imagine that I would be able to move the place that I want to test from. Are you able to help give me some advice on how I do it. I already downloaded tickstory on my VPS, I'm just not sure how to login.
Thank you in advance for any help you can give me.
Re: Can I move where I want to test my data (to a VPS)
Hi Graham,
We can't help you specifically for your VPS setup, however generally speaking it's just as easy as firing up your VPS and then installing Tickstory. You are permitted 2 activations from your license.
Please note also that your subscription has expired. If you would like on-going support and future updates, you can easily renew your subscription by going to Help->About in Tickstory and clicking the "Renew" button. Once renewed, your subscription will again give you access to all the latest features and access to technical support.
