Unable to download tick data to mt5
pmoneyy77
Post by pmoneyy77 »
Product name: Tickstory Lite
Product version: 1.9.8.4
Details:
Requested Clipboard operation did not succeed.
at System.Windows.Forms.Clipboard.ThrowIfFailed(Int32 hr)
at System.Windows.Forms.Clipboard.SetDataObject(Object data, Boolean copy, Int32 retryTimes, Int32 retryDelay)
at System.Windows.Forms.Clipboard.SetText(String text, TextDataFormat format)
at #=ztupk6BSYjsd8X8OrPgapLDA=.#=zWlIl6jOXBzFgrU8$Pw==(Object #=zA0a0C68=, EventArgs #=zqM6uEbU=)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Re: Unable to download tick data to mt5
This looks like an error related to copying information to the clipboard, nothing to do with MT5. Do you have more information about what you are trying to do and the specific steps that are causing your problem? Also, please make sure you are using the latest version just in case the problem has already been addressed in the latest version.
