missing data eurjpy 2016
grobinsongto
Post by grobinsongto »
I exported data to MT5, data is missing for period July 1 2016 to October 31 2016.
Re: missing data eurjpy 2016
Hi Grobinsongto,
We can confirm the data for this period (EURJPY July-Oct 2016) exists on our side. Attached is a screenshot in Tickstory's Data Inspector showing the weekly rows for that period.
You might want to check how you are viewing the information and making sure that the data isn't "missing" due to MT5 display constraints or something similar. I would also check your exported CSV data file to see if the data appears there. That will help identify where the issue lies.
grobinsongto
