Modelling quality - n/a
experienced_tester
Post by experienced_tester »
Hello TS
I want to thank you again for your great job, your software is a real breakthrough.
I've got this minor problem after upgrading the mt4 to 604 build. The strategy report displays "Modelling quality: n/a". I got this for 3 different EA's, 2 pairs and 2 timeframes.
I didn't even notice it for 3-4 days, lol.
I'm using your 1.3RC version and of course I downloaded all data again (I had to). Another detail is that the "99.9%" figure is missing from the Report tab of mt4 after backtest is complete. And yet the horizontal green bar fills its rectangle indicating a 99.9% quality.
I'm using XP Prof SP3.
Thank you, best regards.
Re: Modelling quality - n/a
Hi experienced_tester,
MT4 are currently releasing a flurry of updates that we are trying to keep up with. FYI, All communications regarding the 1.3RC are being discussed in a single post in order to address any issues prior to the official release:
http://www.tickstory.com/forum/viewtopi ... 6&start=20
RC2 has just been released which will hopefully resolve your issue.
experienced_tester
Yes, using RC2 the strategy report normally displays 99.90%. Thank you.
Great to hear - thanks letting us know!
