Volume?
gooly
Volume?
Post by gooly »
I just started on GBPUSD m1 in the start-tester of the mt4 b610 started by Tickstory 1.3 and I see open high low close and then a volume of 42 949 672 985 which is not the volume of a m1 bar but what is this number?
Anybody knows?
Gooly
Re: Volume?
Hi Gooly,
Not sure where you are getting this number from. Can you try to export with the "Suppress volume" option and see if you are getting odd values? If so, then it's most likely MT4 adding something.
Check out this thread for further discussion about volume: http://www.tickstory.com/forum/viewtopic.php?f=2&t=222
