Can I export the ticks with the open platform?
Rodrigo Paitach
Post by Rodrigo Paitach »
Hi tickstory,
Can I export the ticks with the open platform? I'm usually doing tests with a EA and I already want to start exporting to other currency for other tests.
Re: Can I export the ticks with the open platform?
Hi Rodrigo,
Usually you can do this as long as the MT4 Strategy Tester does not have the history files locked. This often happens after you complete a test with a particular currency pair - you can no longer export it again as you'll get a "file in use" error. If you aren't getting this error then everything should export fine.
