first of all - thank you very much for this software.
Especially your integration of the different time zones saves me from a lot of programming.
Now I also want to give you a suggestion.... maybe it will be possible in coming versions to name a folder where the exported csv's can be saved. Because at first glance there can only the downloaded history be stored in a special folder. CSV's go automatically in the program folder.
Thanks for your feedback. That's correct, by default the CSV file goes in the program's run location. You can explicitly specify a specific folder however such as "C:\Exports\{Symbol}.csv". This information will be then saved for the next time you export.
