help
alasdeaguila
help
Post by alasdeaguila »
help me please anyone can tell WHY? after dowload mt4 + ticksoty works well for many time I BT, yes MY BT is ok but after close mt4/ shutdown my computer or add new EA stop work 99 quality :twisted: what I means to get 99 quality I to start over again new mt4 , download again all my pairs :x help
gooly
Re: help
Post by gooly »
Have you checked the links and paths (File => Open Data Folder) after launch?
Are the fxt-file(s) write-protected or are they re-written?
alasdeaguila
Re: help
gooly wrote:Have you checked the links and paths (File => Open Data Folder) after launch?
hi sent pm please
alasdeaguila
Re: help
gooly
Re: help
Post by gooly »
The problem is this your paths aren't the default paths since b600+.
1) Most of the files should go not to s.th like:
C:\Users\me\AppData\Roaming\MetaQuotes\Terminal\F3FCE634953CAFEE1AF7E348742EF8CB\history
2) C:\Program Files (x86) aren't accessible by normal users!!
You can install your MT4 in its own folder and you start it in /portable mode - that is what I do:
C:\Users\me\Documents\MT4.
Look at the other window where you define your MT4 - what have you set there to launch mt4?
alasdeaguila
Re: help
gooly wrote:The problem is this your paths aren't the default paths since b600+.
today I download/setup new mt4 tickstoty
https://www.dropbox.com/s/31ttd47gplhvx ... 5.bmp?dl=0
https://www.dropbox.com/s/nq1y3bw4tkxmm ... 4.bmp?dl=0
Re: help
Hi Alasdeaguila,
As Gooly pointed out, your exported data should reside in a directory outside of "Program Files (x86)", otherwise you will likely run into Windows permission issues. If you go to your MT4 terminal and select 'File->Open Data Folder' you should be shown the location where MT4 is storing its data files and your 'MT4 Settings->Data folder' setting in Tickstory should match.
agora
Re: help
Post by agora »
maybe you can solve your problem by addinng a flase proxy connection to mt4 to avoid metatrader
to connect to the server (i use 1,1,1,1 as Ip).
greetings
alasdeaguila
Re: help
thanks for now is ok storelocation is now in C: users/xxx, I you need to BT 15M we need to download all TF or just 15M ?
gooly
Re: help
Post by gooly »
I don't know for sure but if you load indicators by either iCustom(..) or directly like iATR(..) they will need the hst-files.
Your EA needs only the fxt-file of the TF you want to bt.
