Status Field should show date as yyyy/mm/dd
sryoung12001
Post by sryoung12001 »
Thank you for sharing this very useful program.
I would like to suggest that that Tickstory show the Retrieval Date in format yyyy/mm/dd.
This would allow the user to utilize the existing ability to sort the status field in ascending or descending order to easily check the progress of a requested set of downloads
Re: Status Field should show date as yyyy/mm/dd
Thanks for your feedback, Sryoung. We're considering something a bit more visual such as a progress bar which will hopefully help.
