Add Button Save as Default
rever27
Post by rever27 »
Every time when I export FXT files I need to set Time Zone, TF, Data format ect.
Mostly it's the same information.
I suggest to add Button "Save template"(Save as Default). When user will press it - programm remember last setting which he set.
(Or as an option, offer to Save this set files to some directory to TickStory catalog)
Thx
Re: Add Button Save as Default
Hi Rever27,
Thanks for your suggestion - it has been noted.
