Batch downloads
chifounou
Batch downloads
Post by chifounou »
We can already batch downloads from using keyboard key (SHIfT) to select multiple instruments at once.
It would be better if there was a box system to check/uncheck at the left of each instruments, much like Dukascopy has. Also, have a "Select all" box to use as well.
By the way, if buying you one licence, is it worthy lifetime ? (for every future upgrades for free)
Re: Batch downloads
Hi Chifounou,
Thanks for your feedback. We've noted your suggestion.
Regarding licenses, at the moment we are providing "at least" one month of support & updates for free. We have endeavoured to provide registered users for support for as long a period as possible, however cannot do this indefinitely. This said, the users who have signed up early have received around 3 months of support and updates so far.
