Export data format problem
patrickf127
Post by patrickf127 »
Why my export data format is not symbol.csv ? Please refer to my screen captured file.
Re: Export data format problem
Hi Patrick,
The files you are looking at are the downloaded tick data information, not the CSV file you have exported. Make sure you have specified a full output pathname/filename as mentioned in our documentation.
Please take a moment to go through our help videos here to learn more about exporting:
https://tickstory.com/articles/how-to-d ... ical-data/
https://tickstory.com/articles/how-to-d ... tick-data/
And of course the manual:
https://tickstory.com/help/tickstorylit ... ile_export
