issue with strategy tester
fractalfreak
Post by fractalfreak »
I downloaded the data, I exported it, no error message, and it seems to be in the folder (see screenshot).
Still, the strategy tester does not accept and says "no data".
Any idea?
no data 1.png (7.38 KiB) Viewed 14286 times
Re: issue with strategy tester
Hi Fractalfreak,
Make sure you have not selected "Use date" in the Strategy Tester and try again. It appears that you may have selected a back-test date range that is different to what you have exported.
fractalfreak
I tried that, then the strategy tester jsut takes the last 6 days...
as soon as I try to define a time range (which I made sure that it was downloaded before), it does not work.
Any idea?
I saw some similar issues reported for the new MT4 update...
Thx
If you are using Build 950, the current recommendation is to work with Build 910. Please see here for more:
http://tickstory.com/forum/viewtopic.php?f=2&t=902
fractalfreak
Thx...
do you know when the new version of tickstory compatible with 950 will be online?
Thx a lot for your efforts
Hi Fractalfreak,
We don't have an ETA for 950 build support at this stage - the spread issue in MT4 is a problem. Please keep tabs on the main "1.7 release" thread (or on Facebook) and we'll make an announcement when we have any news.
